5 cubes is a little big for (2) 12s dont you think? Maybe 4-4.5 cubes on that power. I'd also retune. But yeah, you should definitely be hitting more than 133. I did 142 with 1 15 and 1200 watts.
well i have the other amp coming next week and yes they are d2. so just double the power and i can still run at 2ohm correct.
if you strap both amps you can wire it to 2 ohms but each amp will see 1 ohm so each woofer should get ~1500
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
i was shooting for 4.5 but i made a mistake. so its a lil bigger. but it still sounds great. and friggin birch is expensive. they where out of mdf so im going to cut the holes bigger for 2 15's for a buddy of mine and sell it to him for $50
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
I did a 136.8 at the headrest in my standard cab S-10 with 2 RF P2 10's wired to 2 ohms on an RF 450.2 amp. 3.5 cube box peaking at 41 hz...1 year later in doing 141.9 at my last comp with 4 sealed SS 12's on 3k rms which seems like a low score but im peaking 38hz.
I think you should definately go with a smaller box for this.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
140 should be 'easy' with that equipment. In fact something had to have been way, way off to only do a 133.
box is to big and i just pulled up with no tuning at all. but the motherfukker pounds. thats more of what im after.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
