The Saturn: Death-Horn Build/Addition
I know :( I really want to do work
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Got two ribs put in at the front of the horn. At the front the sides will slant slightly like you can see, just trying to keep the basic contour of the car and make the opening as large as possible.
More tomorrow :)
Team Tupperware
Alright...got the back window pulled this morning..
Made myself a bridge to get right over the port to do work...
What i had to start...:(
Got the lower hump glassed down into the port...
Prepped the top piece with the pocket-hole jig...
More glass added, upto one layer of cloth and 4 layers of mat at this point iirc...
This is what doin work looks like :)
Got the contour for the side cut out of some birch..
Got them screwed down...
And I got upto 6 layers of mat ontop of the cloth layer iirc, bodyfilled a bit, sanded, then a layer of milkshake put on..
Still a bit shotty on even'ness but its getting there...more tomorrow, the bottom hump should be done and the back piece mounted and reinforced/glassed from behind if weathers nice...
And the side pieces arent lined up with the vertical pieces because im going to glass over to the pillar pretty drastically and that will fill the gap in :)
Team Tupperware
Thanks guys :)
And I got some more done...
More as it happens
Team Tupperware
Looks like you finally got busy........ great looking work man, keep the pics blah blah
Does this smell funny to you? Its your sister :roflmao:
dammmnn looks sexy dude... almost done with my saturn build :) what year is yours??
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
Thanks guys. And my saturn is a 97 SL2, the best one out there imo and so easy to work on.
Team Tupperware
I wanna hear that!
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
