it really works. your car is just a big box (technically) and those little things change the way the air moves. and SPL is about moving a shitload of air :D
All these really are just tricks of the trade that you'll only really find out from time on a meter... Even if it's not a TL, just one that's consistent like an AC mic can still tell u if you gain or not.
Pioneer AVIC-N2
yeah, i know there are many variables that can help or hurt your score but some of that is just funny as fuck! i can see putting tape over the vents and shit like that but your glovebox open and one visor down???? but try it and hell if it works stick with it i guess!!!!
It's all about building pressure in that little corner of your windscreen.
Go chuck a pebble in a stream some time. It's just one little pebble in a whole lot of water but look at what a difference it makes to the flow around and over it...
Some extreme guys stick squares of sandpaper to strategic panels in their vehicles to change the airflow over them...
10.x volts fo' life!
now thats something
and yeah its all about those little tweeks
for the explorer she likes passenger seat all the way back drivers seat pushed up front and tilted towards the steering wheel with the visors down and all the vents closed
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1405 Guests (See full list)
