need help with sub ohm level
im hookin up (2) dual 1 ohm subs to a 2 ohm monoblock . anyone know how to run bolth subs to the amp for a 2 ohm level?? for some reason i can only come up with ether a 1 ohm load or a 4 ohm load . . is it possible to run 2 dual 1 ohm subs at 2 ohm ?? (google was of no help on this one) thanks guys !
1 and 4 ohm is all you will be able to get with those subs.
damn, thought so . ah well its no ground pounder so 4 should work for now. thanks man...
if its a decent class d monoblock at least youll still have a good bit of effeciency :)
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
its all good , hooked them up at 4 ohm . they seem to have enough power for now . plus i dont have to worry about stretchin the amp . i found this site that has quite a few different wire diagrams on it , but unfortunatly nothing on 1 ohm coils . from what i gather they are far and few between when it comes to your " average " type of system. thanks for the help guys, much appreciated :)
Or you couldn't he do a 2ohm on one and then a .5 on the other to be 2.5-3 ?
Ehh, wut?
Yeah, you could do this, but the one @ 2 ohms would see 4 times as much power as the one at 0.5 ohms...
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1494 Guests (See full list)
