k3n12ock Posted March 19, 2010 Report Posted March 19, 2010 So I have this hum/whine still from my mids/highs. This started back in November/December when my sub funked up. I have since changed everything (new recone on sub, new sub amp, new mids & highs amp, new mids & highs, new HU, new power & ground wire, new speaker wires, all new RCA's). The one thing I have not changed is the EQ. Even with the rca's directly to the HU the whine/hum is still there. I've troubleshooted like a mofo and it's frustrating. Anyway, could having too many things grounded together be the cause? I have the grounds from the HU, EQ, Ipod cord, and Volt meter all together. Could that be the cause of it? I have also changed the mid/high amp ground to my rear battery as well; still hum/whine. Just thought I'd throw this out there if all the grounds behind my dash could be the cause. Will test it tomorrow. A few notes: -rcas are run on one side and power wires on the other -rcas & speakers wires are not near any power/ground wires -new mid/high rca's reduced the hum/whine a bit but still noticable 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
EVAlonSo Posted March 19, 2010 Report Posted March 19, 2010 So I have this hum/whine still from my mids/highs. This started back in November/December when my sub funked up. I have since changed everything (new recone on sub, new sub amp, new mids & highs amp, new mids & highs, new HU, new power & ground wire, new speaker wires, all new RCA's). The one thing I have not changed is the EQ. Even with the rca's directly to the HU the whine/hum is still there. I've troubleshooted like a mofo and it's frustrating. Anyway, could having too many things grounded together be the cause? I have the grounds from the HU, EQ, Ipod cord, and Volt meter all together. Could that be the cause of it? I have also changed the mid/high amp ground to my rear battery as well; still hum/whine. Just thought I'd throw this out there if all the grounds behind my dash could be the cause. Will test it tomorrow. A few notes: -rcas are run on one side and power wires on the other -rcas & speakers wires are not near any power/ground wires -new mid/high rca's reduced the hum/whine a bit but still noticable Have you ran a ground from your HU ground to your amp ground? Are your RCAs ran on the opposite side of your power wire? Do you have a pioneer radio? if so and you have done everything mentioned above, ground your RCAs. http://i22.photobucket.com/albums/b342/Ultimate157/PioneerFix.jpg A good way to trouble shoot to see whether its your signal or a bad ground, get an ipod with a 3mm to RCA cable and hook it up to your amp. if it still whines, bad ground. if the whine its gone, its the signal.
uhoh_45 Posted March 19, 2010 Report Posted March 19, 2010 what kind Hu? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
dwz Posted March 19, 2010 Report Posted March 19, 2010 Please follow the steps in the website below http://www.termpro.com/articles/noise.html
k3n12ock Posted March 19, 2010 Author Report Posted March 19, 2010 Have you ran a ground from your HU ground to your amp ground? Are your RCAs ran on the opposite side of your power wire? Do you have a pioneer radio? if so and you have done everything mentioned above, ground your RCAs. http://i22.photobucket.com/albums/b342/Ultimate157/PioneerFix.jpg A good way to trouble shoot to see whether its your signal or a bad ground, get an ipod with a 3mm to RCA cable and hook it up to your amp. if it still whines, bad ground. if the whine its gone, its the signal. -No -Yes -No what kind Hu? Alpine 7893 Please follow the steps in the website below http://www.termpro.com/articles/noise.html GOOD STUFF! Off to mess with my car 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
