Re-attatchng Spider...
Guest jbinn
ill probably just send it in since im almost deffinate it should be covered, the cap just came off like the glue let go... on the next one i get if i do get one im going to add my own adhesive over theirs just to make sure.
By lining the sub up, they mean the coil in the magnetic gap.
I think you will be ok to glue it back down with CA glue or Epoxy since the original glue is probably still there and keeping everything aligned already by itself.. just glue the crap out of it (more glue the better haha) and give it hell :)
Hammerdown... 1%
I would also use epoxy in this case. I would put plenty of epoxy on the spider landing and then take a smaller screw driver and press it evenly around the spider to hold it down and then wipe the excess epoxy of the spider and basket of the sub. Make sure and get the fast drying epoxy. Do this if you CAN'T send it back.I hope you learned not to buy cheaper subs.
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
