Alright I got you know so get 1 RockFord Fosgate T200001bd and it will run all 3 12inch w7s?
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
yes....that will be plenty.i have a t1000.1bd for 2 12w7's and it puts out about 1600 watts.
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
doesnt everyone want thier subs to put out bass? DUH
:lol:
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
jasonw30 did you recvive my PM?
Would 3 Kicker 12L7 be better than 3 JL Audio W7?
Kicker 12 inch L7 : Peak Power Handling 1500 Watt
Frequency Response 20 Hz - 100 Hz
Sensitivity 87.4 dB
Impedance 4 ohm (Dual Coil)
JL audio12 inch w7 : Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 750W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
i would personally go with the Jl audio
Just a question my man; Why are you set on JL? You said you wanted to get LOUD. JL's will get loud, but they are not the loudest, not by far. And nothings says 'Back off muffugga, I got king kong in tha trunk' like an 18". Trust me kiddo, if you got room for three 12's and all of the relevant boxes, amps, batteries and gear in the trunk, you got room for an eighteen banger.
Put really, really simply; What are you doing? You said you wanted bass from the subs and sound from the mid/high's. Shit, a pair of XPLOD 6.5's will put out mid/high and a Pyle 10 banger will put out bass, but it will be about as useful as a one legged man in an arse kicking contest. If you want LOUD and price is no exception, try brands such as FI, TC Sounds, DC, RE etc. If you want Loud with good SQ, try brands such as FI (Q), IDMAX, etc. The JL's will also be fine in that catagory, as they are a good SQL woofer (IMO). If you want SQ, W7's are just barkin' up the wrong tree.
I ain't raggin on your setup my man, I just don't want to see a brother make choices on looks and 'street cred' alone. If you think the W7's are what you really want, you've heard them and you are dead set, then I can't wait to see yo install mang. If it ain't loud and it ain't low, then it ain't worth it.
Good luck with your install mang.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
i like my w7's,but they do make louder subs for less money.my setup is not so much about all bass.
don't get me wrong,it still gets really loud.just like whats posted above,SQL is JL,SPL is not.
your choice man.i would not do kicker.try Fi,DD,RE,ect....
eclipse cd2000
rf p4004
