XpEnSiVeHaBiTz08 Posted June 21, 2007 Report Posted June 21, 2007 i know this is a little off topic but im looking to build a hydraulic boat trailer and was wondering if the hydraulic cylinders and supposed to be on a certain angle in order for them to lift right? thanks mike Quote
*1LOWSUV* Posted June 25, 2007 Report Posted June 25, 2007 You could use a heim Joint on both ends and mount it at pretty much any angle you need. Used these alot back in the 80's on Mini-Trucks for the Double-Diamonds. Quote [email protected]
Pitbullx Posted July 6, 2007 Report Posted July 6, 2007 You could use a heim Joint on both ends and mount it at pretty much any angle you need. Used these alot back in the 80's on Mini-Trucks for the Double-Diamonds. think a Powerball would work in this app? Quote Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Big P Posted July 7, 2007 Report Posted July 7, 2007 are you wanting to put it on the tounge so you can launch in shallow water or haul skis over the top of your boat? Quote
