Twiztidsetup Posted March 25, 2010 Report Posted March 25, 2010 I just found this out that my deck is a 2v pre output and my amplifier gain output volt is set at 8v. Because it gives me the most bang. Am I wrong but this is bad due to high distortion? Can I atleast set it at 4v because if set at 2v it bairly puts out. If I upgraded my deck to a 4v or 5v pre output would my system be louder with less distortion , setting my amp to 4v or 8v? Im pretty confused on this because my amp is set at 8v right now.Being that it is the loudest. What should I be doing? Thanks Amplifier: dpx11551 Deck: CDXGT240
Mr. Darkjustice Posted March 25, 2010 Report Posted March 25, 2010 my indash is the same way, so i just ran a linedriver to boost its volt rms without distorting. a normal HU would give it better sound but an eq/linedriver would be a cheaper alternative Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward The Revolution Was Not Televised But There Is This Thread(clicky) Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
Twiztidsetup Posted March 25, 2010 Author Report Posted March 25, 2010 Id rather buy a new deck and not mess with a linedriver. Can anyone else answer my questions? Thanks
MikeyF Posted March 25, 2010 Report Posted March 25, 2010 8v gain is all the way up on your amp, correct? If so, you are clipping the shit out of your speakers in the first place, and would be one reason it sounds so distorted.... 12" DC LVL 4 Sundown 1200D PG RSDs PPI PC2100 Alpine 9886
Twiztidsetup Posted March 25, 2010 Author Report Posted March 25, 2010 8v gain is all the way up on your amp, correct? If so, you are clipping the shit out of your speakers in the first place, and would be one reason it sounds so distorted.... yes 8v is all the way up. Could this be why the infinitys I took back were making a smokey smell? hahaha. I phucked up ... I think it should be well told through these forums. I bet alot of people mistake this I never knew about it.. but then again I might be mental You think 4v on my amp would be ok? 2v bairly puts out any bass.
huh?do-what? Posted March 25, 2010 Report Posted March 25, 2010 yes 8v is all the way up. Could this be why the infinitys I took back were making a smokey smell? hahaha. I phucked up ... I think it should be well told through these forums. I bet alot of people mistake this I never knew about it.. but then again I might be mental we're all a little mental. God damn its hot today. My balls are stuck to my leg.
Guest Posted March 25, 2010 Report Posted March 25, 2010 from what i remember the lower the number on the gain knob (like .2v) is louder than a higher number (like 8v) its probably quiet at 2v for you because theres something wrong with the settings on your headunit, such as the subwoofer level being down. my headunit has 2v preouts and my gain is at like 3v because i dont want to output all the power to my speaker since it wouldnt be able to handle it but thats another story.
Mr. Darkjustice Posted March 25, 2010 Report Posted March 25, 2010 i honestly dont know how much off the actual volt you can set it, i set mine as close as possible Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward The Revolution Was Not Televised But There Is This Thread(clicky) Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
MikeyF Posted March 25, 2010 Report Posted March 25, 2010 yes 8v is all the way up. Could this be why the infinitys I took back were making a smokey smell? hahaha. I phucked up ... I think it should be well told through these forums. I bet alot of people mistake this I never knew about it.. but then again I might be mental You think 4v on my amp would be ok? 2v bairly puts out any bass. Yes, that could definitely be the reason why they were smokey smelling. Turn that down ASAP. 12" DC LVL 4 Sundown 1200D PG RSDs PPI PC2100 Alpine 9886
Twiztidsetup Posted March 25, 2010 Author Report Posted March 25, 2010 from what i remember the lower the number on the gain knob (like .2v) is louder than a higher number (like 8v) its probably quiet at 2v for you because theres something wrong with the settings on your headunit, such as the subwoofer level being down. my headunit has 2v preouts and my gain is at like 3v because i dont want to output all the power to my speaker since it wouldnt be able to handle it but thats another story. Hmm thats weird because all the expensive decks put out 4v - 8v. And my 8v set on the amp is loud as hell. Maybe theres bairly any bass at 2v because I have to turn my gain up to compensate from the 8v it was on.. because I have it on 8v with a low gain, 2v with a higher gain would prob compensate.. IDK The reason I never knew this is because 90% of the damn gain tuning guides dont say anything about the gain volts! They need to update this before people blow there subs like I did. My system sounds clean because my gain is only 1/4th on due to break in on my new cvr subs even on 8v with the 2v deck I will be clicking that button down to 2v and re-tune it asap. As soon as the doctor office way across the street closes haha. Doc came over yesterday and complained about me shaking everything in his office's and customers . I was nice about it and said it will never happen again.
