6 Crossfire 18s Hummer RE-RE-RE-RE-BUILD
pix uploading now...
who wants to see? is anyone awake??? :) been a long day of sanding, working on alternator setup and also working on the step down 993 from XS Power in the Boswell's metro (DDBEAST... which will be getting some upgrade work here soon... :) hehe)
So I have been going at it since 9am this morning til 11pm tonite... i'm pooped. lol
anyway, pix uploading now... be up in a few...
:ttiwwop:
Johns.jpgSuburban Coming Soon
ok... alternator...
I worked on this between letting the fiberglass dry (no wasted time)
This is the old wiring, if you look closely you will see only 0ne alternator is actually getting power to the Lwire and the VCM was blank... not sure who did what on this... but nonetheless... we are gonna get it cleaned up... (again thanks to Nate at XS Power for the troubleshooting help as I'm not an XS Power guy (I use Batcap and Excessive Amperage). It's actually pretty easy and straightforward, however with having 4 alts, there is a bit of extra wiring not included with the harness cables that were not mentioned in the installation manuals.
So here we go...
Old install/wiring...
new harness in, extra wires attatched...
sexy! i love this build! :D
04' Chevy Blazer
-Kenwood KIV-BT900, Infinity Kappa 462.9cfp's, Rockford P1653's, Subs... Ridin Stock-
ok back to the front doors...
a layer of "magic mix" is applied...
then it's sanded to 40grit...
then taping the edges of the door, mounting the panel (temporary) and edge the panels using a short strand fiberglass/kevlar reinforced body filler, this stuff is like stone...
then it gets sanded smoother... down to 80grit... and tested again for fitment...
the same thing repeated on the other door panel...
next is sanding down to paint prep... and paint... hopefully I will have them painted by tomorrow, that's my goal. :)
stay tuned...
hows the voltage now ric?
I actually posted that earlier in another post...
it was sitting around 14.3-14.6 or so... now its at 15.5 and all four alts are charging... like Nate said... extra volt and another 900 amps of current should definitely help with delivering more power. :)
sorry man i didn't know you talked about it early :pardon:
but that should deff help out alot! are you going to charge higher? well if you have played it does it sound any louder to the ear-o-meter
