I need to get my back suspension off the bump stops in my Grand Prix. The factory design uses a fiberglass transverse monoleaf which seriously has a wheel rate of like 10 lb/in. I'm a weakling and I can push the back to the bumpstops. Anyhow, I found a set of helper springs and was wondering if anyone had dealt with them before.
http://www.jcwhitney.com/quick-change-helpers/p2005887.jcwx
Anyone have any input? It's a universal kit so some cutting will be needed I'm sure, but all the same if it does it's job that's all that matters. If it jacks up the back end I'm willing to disconnect the factory spring.
Too many projects, too little time...
I suggest getting these:
A couple sets of:
http://www.jcwhitney.com/ring-type-coil-spring-stabilizer/p2005889.jcwx
And a set of:
http://www.jcwhitney.com/1000-adjustable-air-spring-sets/p2005927.jcwx
I threw them on the back of my PT and got a 3" lift. Now the car sits level haha.
There's almost nothing to the install. It took me a few hours with no help and only a few tools.
Need an install? Hit me up.
[email protected]
The Grand Prix applications only go up to 1987 model year. I couldn't find any air shocks for my car either.
Edited by ktownsdriftking
relocate the shock, just get some upper and lower shock mounts and weld them on. the airlift helper bags are the way to go to fix this problem.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
On a sedan, it's not that easy.
[HOONIGAN]*
'01 Ford F-250 LWB
JVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
