I know im gonna get bashed about this brand, but here it goes. Has anyone ever used the SoundStorm Evolution series amps?? I can get a couple for very, very cheap. I might get them just to play with, just wondering if anybody has seen them personally.
These are 3000rms a 1 ohm.
SMD Super Seller
My Feedback Thread
never used one but did report an ebay seller for trying to sell them as Soundstream about 2 weeks ago. Good luck with them and please let me know how they do.
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
What I dont get is why all these Max Brands are always 2 channel amps. I guess it appeals to the dont knows that think to run two subs you need 2 channels.
¿ǝɯɐƃ ǝɥʇ
This X2. It is probably the first thing i have to explain to friends when they ask about getting a sound system...
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
They wont do near rated power here is the Fusing of them that I found.
Important installation
considerations for using
this amplifier.
The fuse ratings for these amps
EV3000D: 60A (30A x 2)
EV4000D: 120A (40A x 3)
EV5000D: 175A (ANL type)
Although sufficient for normal working
conditions, overloading the amp
result in blown fuses. Please try
avoid overloading the amp in this
manner.
Your EVOLUTION Class D amplifier
is designed to run with
a minimum load of 1 Ohm.
Operating the EV3000D ,
EV4000D or EV5000D with
speaker impedance load below
1 Ohm may result in poor
sound quality and damage
the amplifier circuitry. Such
damage is not covered under
the warranty for this product.
Do not mistake the input level control
for a volume control! It is designed
ONLY to match the output level
your audio source to the input
of your amplifier.
Do not adjust this input level to
maximum unless your input level
requires it.
Ignoring these instructions will result
in an input overload to the amplifier,
and excessive audio distortion.
can also cause the protection circuit
to engage.
Don't misuse the
level control!
¿ǝɯɐƃ ǝɥʇ
SoundStorm EV3000d will never output that kind of power. 2x30amp fuses times 14.4volts = 864wrms \ .707 = 1222.065MAX.
I think my math is right. Feeling kinda sick right now, so could be off.
At least it has 1/0 power inputs. That's a plus.
You'd actually be better off getting the EV-5000d. It comes with a 175amp fuse. Even though it probably still wouldn't output the rated power, it looks like it'd be closer.
175x14.4=2520watts/.707=3564.36MAX
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
Thanks..
At least I was sort of on the right track.. heheh.
