5KW +
rc.btl
As far as stetsom amps, people bash them because they bsically use the parts that other companies use. but the parts that one company uses to make a 2kw amp stetsom uses to make a 5kw amp. So the point being is that they push their stuff to the limit to produce the power. Take a look at the 7kd or w.e it is and youll be like damn that amp is small compared to other lower 4kw amps from other companies.
Very, VERY misleading information here. The Stetsoms use TO-247 output parts but that's where the similarity ends.
Standard Zenon output FET, IRFP360LC - 400V, 23A, 280W
Stetsom 10kd output FET, IRFP90N20D - 200V, 94A, 580W
Saying they use 'the same parts' is like saying a Ford Ka and a Lamborghini Diablo are the same because they both have 4 wheels.
10.x volts fo' life!
Sundown 4500 if you want quality and good service. Or you can look into 2 AQ 3500 strapped. They do there rated power strapped. Not too shabby of price either.
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Thanks for correcting me, and while im sure you're right for the most part. and while ive never owned a stetsom, alot of people have said similar things regarding these amps, and thier parts, about being over driven to squeeze out power if you will--
so ive read things like that many many times and those claims have to mean something, its not like i got that idea from nowhere ya know.
a Ka vs a diablo is a bit extreme though... maybe like a mustang or an svt focus but a ka..? lol jk
but back on topic, i dont remember anyone mentioning anything from hifonics-- you could always look at them like a Colosus or a Goliath iirc
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
This is true, they have a bit of a bad rep. Part of it is just hate/jealousy against Alan Dante though, I think.
There are some issues with them, definitely.
The early ones especially have some design flaws. Mine have bits of the PCB scratched off with an Xacto knife because otherwise they would have shorted out. Plus there's a few other issues with them from the way they are built and the techniques and materials used. Just to give you an idea... I can de-solder MOSFETs from a Stetsom with a 60w soldering iron but removing them from a Zenon usually requires pre-heating the larger masks with either a hot air station or a mini-blowtorch. Koreans using higher temperature, higher quality solder I can only assume. Plus it's so so easy to pull vias on my earlyish Stetsom boards whereas the Zenons tend to be fairly tough except where they cram larger parts into positions made for smaller ones.
I am sure with a little bit of time Stetsoms big amps will come of age and then they'll be hard to beat. The shear amount of real, raw CLEAN power from a package that small is impossible to ignore.
Just be wary about repeating stuff you have heard from people on the internet like it's fact. A lot of the time they're just repeating rumours themselves :)
Yea Allan Dante Is a beast for sure and thanks for clearing that up. I just think its something to consider about Stetsom amps for the OP I wasn't trying to bash but instead offer another perspective. But I know what you mean about people twisting info around.
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 2161 Guests (See full list)
