I used to do civic motor swaps all the time. Put a jack under the engine. Disconnect the tranny from motor. Undo the motor mounts. Three or four guys with balls to lift it out.
It helps if you deadlift 600 like me B)
helpful part is that the tranny is staying in the engine bay. so only the longblock is getting lifted out and replaced. again, the motor only weighs around 300 lbs. so i'll get two others to lower it in, one on one side to get the mounts and myself on the otherside with the other mount and checking clearences. woo 200 posts : )
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
edit: most posts today so far : ) WOO I HAVE NO LIFE : )
Enclosure: n/a : (
Subwoofers: n/a : (
You can rent one from Advance Auto for a few days, and I'm sure other auto part stores too.
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
you know about pricing on those? that would make this alot easier and take alot less time lol
Enclosure: n/a : (
Subwoofers: n/a : (
I can do that too. ;)
Need an install? Hit me up.
[email protected]
i wish i could : ( my max rep deadlift is like 350
Enclosure: n/a : (
Subwoofers: n/a : (
Well there you go, the motors only 300 :lol:
im gonna run down to advance here in a few hours once it opens, 5AM here, and see how much an engine hoist will run me, if its outrageous then i'll get the gang down here and pull the bitch sometime in the next few days
Enclosure: n/a : (
Subwoofers: n/a : (
nvm, got a hoist yesterday offa my friend aka "dakotaspeir" on smd. so it'll be alot easier now : ) just gotta get a few friends to help me still.
Enclosure: n/a : (
Subwoofers: n/a : (
next question is: whats the best way to pull a motor with a hoist, but leaving the tranny in the car... i dont have the tools to get the axles off (need a 32mm to get axle nut off and dont have it nor air ratchet) so pulling the tranny isnt really an option at the moment, which would be easiest? the transmission has to come apart from the block either way, im reusing it on the new motor. both options are about the same in work wise.
Enclosure: n/a : (
Subwoofers: n/a : (
