Kick Pods - Pics
Eh I just use old t shirts to stretch over my shit. Although you could use some spandex type material. A lot more stretchy. And pick up some CA glue to attach the fabric at the back, the hot glue I used to use made it much harder to sand off the excess on the back.
To countersink cut a bigger ring and glue it to the other one. Do the inside cut of the flush trim ring with a router, because anything else will show imperfections, I don't care how good you are with a jigsaw. Unless you sand it a bunch that is.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Can you use the shirts on larger stuff like boxes
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
You have no idea how long I have been trying to figure that out thanks.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
once you get the kick panels made how do you attach them?
before i stretched the material, i glassed in small blocks of MDF onto the mold...Now I can just put a couple screws thru the stock panel into the wood blocks and then put the stock panel back in. It makes a couple holes in the stock panel, but its worth it.
Subwoofer Wall
New updates!! Well I decided against the vinyl, partially because I quit my job at the audio shop today and didnt have easy access to free vinyl or free contact adhesive ($50 per gallon). But I painted it a textured paint, looks real nice in my opinion. I'm not sure how well the colors going to look in the car yet though. And I have a few pics of my amp rack.
primed/sanded:
Posted Image
primed again:
Posted Image
painted:
Posted Image
Posted Image
Posted Image
started running wires:
Posted Image
xover mounted under the dash mostly out of sight:
Posted Image
amps:
Posted Image
Posted Image
Subwoofer Wall
Looks good dude do you buy a textered paint in like a spray can and if so where? Dude why did you quit at the audio shop
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
