Mosin Posted April 5, 2010 Report Posted April 5, 2010 Do I place ground from amp to 2nd batt then to ground or straight to ground? Derp.
ktm300 Posted April 5, 2010 Report Posted April 5, 2010 Run it all to the 2nd batt, just make sure both batts are connected. There was someone a while back trying to run his system off just the 2nd batt without having it connected so it could get a charge..
Mosin Posted April 5, 2010 Author Report Posted April 5, 2010 Okay I'll ground to 2nd batt then to vehicle. Thanks Derp.
bayoublaster Posted April 5, 2010 Report Posted April 5, 2010 Run it all to the 2nd batt, just make sure both batts are connected. There was someone a while back trying to run his system off just the 2nd batt without having it connected so it could get a charge.. I am doing a new install using two batterys (Kinetik); one cranking and one deticated for the audio system. I am running 0 Gauge cables from cranking battery (+) to the audio battery (+). So if I read correctly I should conect both (+) and (-) terminations between both batterys so that they both will charge? Should I still terminate a ground local to my audio battery that will be located in the rear of my Yukon?
