hdorre Posted April 5, 2010 Report Posted April 5, 2010 Would my enclosure tuning be the same whether I have the port sticking inside or outside the box? is an aero port just PVC pipe? In order to install, do I just cut another circle in the enclosure and put the pipe in the hole? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Hotdog Posted April 5, 2010 Report Posted April 5, 2010 Would my enclosure tuning be the same whether I have the port sticking inside or outside the box? is an aero port just PVC pipe? In order to install, do I just cut another circle in the enclosure and put the pipe in the hole? Question 1 = Yes Question two = Mostly Question thee = I can not answer because you need to know the inside dimensions of the box, the size of subs and displacement, then you can figure port length and size. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Afrodeezyak Posted April 5, 2010 Report Posted April 5, 2010 Question 1 = Yes Question two = Mostly Question thee = I can not answer because you need to know the inside dimensions of the box, the size of subs and displacement, then you can figure port length and size. if the port was external, wouldnt that change the tuning compared to if the port was inside the box? i would think that the tuning would be higher if the port was built inside of the box because it takes some of the available air space.
Chris from Mi Posted April 5, 2010 Report Posted April 5, 2010 1. inside decreases airspace slightly, so the tuning will be slightly higher inside the box as opposed to slightly lower if outside the box. 2. it is just pvc pipe, however the ends are flared and one end already has a flange on it ready to be mounted. 3. yes, to install all you do is trace the outline of the smaller flare (non mounted flare) and it is exactly the mounting diameter for the flanged flare (for precision port aeroports) Precision Port Products aeroport Orion 2500D, Jbl Gto 75.4 Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids Alpine cda-105 optima up front Knu klm 1/0
hdorre Posted April 5, 2010 Author Report Posted April 5, 2010 Is this calculator designed for internal or external mounting of the aero port? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
