okay, im a little confused about the power for alts. im about to buy a high output one for my 3000gt..its 220amp. is this good or should i go bigger? im going to be powering 4000wrms. what exactly does 220 amps mean? thank you!
260 iraggi alt
Yellow Top for the front
1 18" Solo x
1 Memphis Mojo 16-MCD4KW (4000wrms)
All 1/0 Wiring
2 250 Amp Circuit Breakers
BIG 3 1/0
1 Mits. 3000GT
220 Amps means the alterator produces an average peak of 220 amperes of current, which at 14.4 volts is 3,168 watts of power.
If your volts dip, you lose power. If you dont run in the peak RPM range, you lose power. It doesnt matter though given that you will not be feeding your system 4000w RMS and driving for extended periods of time, so any time the system does require more than the alternator can give it will just take it from the battery (as long as the battery(ies) are ok).
Hammerdown... 1%
thank you for your helpful info! i appreciate it! :D dont know how you knew it was 3/168 watts, but im sure i can figure it out eventually..obviously 220 amps puts that much watts..once again thank you!
260 iraggi alt
1 18" Solo x
All 1/0 Wiring
BIG 3 1/0
1 Mits. 3000GT
amps X volts = 3168 thats how he got it, he took 220 amps X 14.4 volts
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
oOOOoh! thank you very much! :D
260 iraggi alt
1 18" Solo x
All 1/0 Wiring
BIG 3 1/0
1 Mits. 3000GT
good luck getting that mother fucker in...
o wait u probably have the dohc...still a son of a bitch to get in....
Eclipse cd7000
any advice? :D
260 iraggi alt
1 18" Solo x
All 1/0 Wiring
BIG 3 1/0
1 Mits. 3000GT
install it outside of the dealership and swear a lot while doing it.
Hammerdown... 1%
Good info right there
  • Who's Online   1 Member, 0 Anonymous, 1575 Guests (See full list)
