Want Infor About Fi Ssd Subs
dcofer
im am looking at buying two 10" FI SSd sometime in the next two years lol (gotta get the money first :) ) but i have a question. that is the sirst brand where i have seen options when ordering and i was wondering if someone could explain what they are before i go and jus throw money into the sub. how does each option improve the sub and sound and is it truly worth the cost? keep in mind i am building a SQ system that i want to hit hard when i want it too but good clean loud bass and quality are my main goals. so before i fully considered these subs i wanted to know a little more about them from the users like all you ppl :) thank you
there is a website for that, plus a thread here on SMD
www.ficaraudio.com
ok, i have read the information o nthose sites, but what is the BP power option? its an extra $40 so it has to be worth it to make me pay that much for it. and i couldnt find anything on that aspect so instead of a link can i get a quick cut and paste from where the link is for or jus a quick explination. thanks :)
BP option
"This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack for a little extra mechanical ability.
All of these new features increase power handling from 200-500 Watts depending on the application.
Its just another way of tuning and tailoring your subs to your exact needs.
Now this is not something for everyone and I dont think that most people need to add it. But we are getting more and more bassrace applications where being able to stack more power to ge the sub to its linear limits for a specific application requires more than the rated RMS power (often quite a bit more) and this option allows you to push things a little harder for some applications. If you are looking for a SQ setup or just a clean daily setup within the normal limits of the subs... then there is no point.
Would I recommend it to someone with 1200W in a daily driver? I doubt it as it really wouldnt be needed and the extra 200W really isnt an issue. Its the guys that are trying to stack on 1800W and push them as hard as possible for 30 seconds (or try to all day) while voltage starts to drop and things start to get ugly towards the end." -Scott
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
  • Who's Online   1 Member, 0 Anonymous, 917 Guests (See full list)
