I am going to get a second battery for my system, and I dont want to spend 350 bucks on a 3100. what do you guys recomend? I was thinking optima lmk
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
How much power are you running? Just be happy the 3100 is only $350, I gotta pay $425 to get it to hawaii. You could go with Optima, Kinetik, Shuriken, etc but which battery you should get is going to be determined by how much power you're running.
well right now im running a kicker 1500.1
Skyhigh wire
some batteries
Well then if you wanted to just go with the power you're running now and not worry about upgrading later you could go with a Kinetik HC1800 or HC 2400, an Optima Redtop or 2 would probably be suffice, you could do an smaller XS Power battery perhaps a D5100? Shuriken BT-60 or BT-8 0 would also work.
Something I forgot to ask, what kind of battery are you running up front? I personally wouldn't mix wet cell batteries with an AGM type of battery. Depending on what kind of battery you're running up front, maybe just upgrading your front battery instead of adding a second one would be beneficial. An XS Power D3400 would be more than sufficient, and it should be well under $300.
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
