i need a blowthrough box design asap so i can get started on a customers request.
i have 58 wide 17.75 height and 18.75 depth.
ported most likely say tuned around 34
its for 2 L7 15s powered by a kicker 1500.1 ill paypal u $10
trying to get decently loud here
TEAM FLEX ISSUES
Alpine cda 9886
4 AA Mayhem 15"s dual 1.4
1 Dc 9k
10.5 cubes tuned at 36hz
156.1 dash 154.6 meca mod 4 157.0 kick
2 xs power d3100s
mechman 270 amp
2011 Ca state champ meca modified 4 and p&p 4..
VIDEOS.............BUILD LOG
anyone come on now.. as long as the cut out is not too big..
TEAM FLEX ISSUES
Alpine cda 9886
1 Dc 9k
2 xs power d3100s
mechman 270 amp
cutthrough box is no different from a normal box. you just make a big hole in your cab and seal it off. unless you are tring some kooky bandpass design and what not.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
something that will work in the space i have just dont want the cut out to be so big
TEAM FLEX ISSUES
Alpine cda 9886
1 Dc 9k
2 xs power d3100s
mechman 270 amp
Big problem i see would be getting to 34 hz tuning with a good SQ of port, no way you can get a little bit bigger?? maybe a couple of inches more on depth.
cant get any deeper than that as the truck is tubbed since its bagged
TEAM FLEX ISSUES
Alpine cda 9886
1 Dc 9k
2 xs power d3100s
mechman 270 amp
For a kicker L7 i would get 4 cubic feet per sub so you can get the lows damn hard!! With the amount of space you got there, only way to get 4 cubic feet per sub it´s with a very small port, said that, i would then use 3.5 c/f per sub with a very nice port and tune to your 34 hz.
This box would give you 7.2 cubic feet after displacement, 16SQ of port per cubic feet and 35 hz tuning.
3/4" wood and get a nice double baffle on the front if you can
17.75 x 58 x 18.75 (same measures you gave)
Port:
16.25" x 7" x 25" depth
Resin, nice bracing and some 45´s if you can
Still, small box so maybe you need a little bit of power. I can´t say that this is the best box ever because i don´t even work as a car audio installer, professional box designer or anything, but thank god every box i have designed in the past has worked :D
By the way, i can shrink the port size a little bit to gain some internal space and still don´t lose output, maybe getting 7.6 c/f and about 14SQ of port per cubic feet.
the design??
TEAM FLEX ISSUES
Alpine cda 9886
1 Dc 9k
2 xs power d3100s
mechman 270 amp
whatever u think will work best
TEAM FLEX ISSUES
Alpine cda 9886
1 Dc 9k
2 xs power d3100s
mechman 270 amp
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
