so i can replace the stock battery under the hood with a kinetik hc600 and the big 3 and er thing will be good? i think he already has a yellow top optima from the install i did from his old car, will that work?
no,yellow top as main battery and hc 600 as backup.
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
try a kinetik HC 2000 underhood. seeing he has a Navi it should fit perfectly and it has twice as many cranking amps as one optima battery has. as the fellows suggested, a hc600 would do in the back.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i don't think a 2nd battery is needed... but it will help...
the 300 should have a pretty good alt in it..
you really dont know the current draw on that amp then. it shut off my truck several times. with just the yellowtop i still had my truck shut off (before i had the kinetik) and that lil kinetik 600 has some power to keep that amp going and the truck still running. even on idol at full tilt.
NoFearX18 said:
trainman0978 said:
Guest Nismofreak
that amp will be good enough....I think if you want....you can put 1,600rms if you like....If you would wanna do that get cooling and flatwind coil....
That's right Nismo! Since getting a dual 2ohm sub from FI, he will in actuality be getting a dual 1.4ohm VC sub which he can then wire down to .7ohms to the T1000 -Therefore putting out around 1600rms :D
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
  • Who's Online   0 Members, 0 Anonymous, 1174 Guests (See full list)
