Lanzar Amps?
ndummitt1223
yeah I realize it would be under powering that sub, but its new. I dislike using used amps because you never know how the previous owner used it. 99% of people that own amps don't know how to properly set the amps gains thus damaging the amp, maybe not to the point of failure but still damage will probably be done.
true. i love having to fix systems that have been set up by people with absolutely NO IDEA how to properly match their subs and amp. ohms apparently mean nothing when all you have to do turn up that weird knob that makes it boom boom louder
i think the bar thats been set for you needs to be raised a little buddy =)
whats your city and location?
puerto rico but we have everything over here from nippon to DD im pushing 4 L7 d4 with a 1400 it come with 4 30 amp fuse and a damping factor of 300. it nocks day and nigth my friend its happy with it.the system is going to be in the car for a year now.O yes 1\2 ohm.
its not the ohm load I'm worried about its the clipping that'll kill it faster then anything
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
thanks for all of the replies guys, i think i will pass on the lanzar and keep searching, maby buy the amp a little later when i have more money, and TeamHT, i live in ohio near the columbus area
To buy list: 1x AQ HDC315 Copper Coil sub, 1x AQ1200D amp, Wood for sub box, Wiring, Car Alarm, Time and MONEY!
I know lanzar is not the best, but they are cheep and put out a lot of power, i can get a lanzar VIBE286 for 100, if you can think of an amp that would be better in the 200 price range please tell me, i a looking to use it on my Fi BTL 15
Bridge output RMS POWER 10000WX1CH car amplifier www.gedunaudio.com
http://www.gedunaudi...w/01/18003.html
XP-10000.1
Class-D mono (Digital) car amplifier
Super-efficient Class-D PWM design runs much cooler
High-efficiency MOSFET power supply
Platinum Plated Heavy Duty Power & Speaker Terminals
Two Amp Linkable Function:
Output Master And Input Slave (yes)
Short circuit / thermal / overload / DC offset protection
Wired Remote Controller
There are two groups of signals convert RCA output
Soft delayed remote turn-on / off circuitry
Fully 1Ω stable operation (Mono only)
Subsonic filter (Mono only)
Variable phase shift (Mono only)
Heavy-duty heatsink
Oversized capacitor tanks
Adjustable low gain control
Power / Protect LED indicators
Model:XP-10000.1
Type Class-D Mono Car amplifier
RMS Power Ratings
1CH 1ohm 10000 Watt
1CH 2ohm 5000 Watt
1CH 4ohm 2500 Watt
T.H.D Tested Voltage & THD : 14.4V & Less Than 1% THD
Signal to Noise > 90db
High-Pass
Low-Pass 25Hz~250Hz
Damping Factor +350
Bass Boost 0 ~ 6 dB
Variable Phase Shift 0 ~ 180 degrees
Double Sided Through Hole Epoxy PCB FR 4 PCB
Input Sensitivity 200mv~6v
Fuses Rating 20A*4 NO!
Dimension (M M) Length (850 mm) * width (260 mm) * height (55 mm)
weight: Net Weight( 16 kg)Gross weight ( 18 kg)
fswudong go to some other website u stupid ass spammer. btw fswodong your reported
ndummitt1223: we need to know whats your budget for an amp. you have a badass sub but you will need an extra battery or 2 some nice wire and of course a nice amp to power the sub. your single battery and stock alt isnt going to hold up long with a decent amp that will power that sub good
2015 silverado crew cab
nothing atm but soon...
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
