Alex K Posted April 16, 2010 Report Posted April 16, 2010 I was looking at the kinetik Hc1800. I would want to eventually want to run 2 of them, so could I put a yellowtop up front, then later put a hc1800 in the trunk? What's a decent yellowtop too? I was looking at autozones website and they have quite a few at my local stores. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
hdorre Posted April 16, 2010 Report Posted April 16, 2010 I was looking at the kinetik Hc1800. I would want to eventually want to run 2 of them, so could I put a yellowtop up front, then later put a hc1800 in the trunk? What's a decent yellowtop too? I was looking at autozones website and they have quite a few at my local stores. I'd go with XS Power. You can buy them online from Mechamn.com and they have pretty good prices. It tells you how many watts it could handle On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
P4killer_ Posted April 16, 2010 Report Posted April 16, 2010 If you want to run 2k rms total, an 1800 or equivalent should be fine. of course the big 3 would help alot, and with two of those or so, you should def be fine. im running 1500w with a 1400 and i dont see below 12.5v full tilt so you should be ok with 1 perfect with 2 Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Ricky A. Posted April 16, 2010 Report Posted April 16, 2010 If you want to run 2k rms total, an 1800 or equivalent should be fine. of course the big 3 would help alot, and with two of those or so, you should def be fine. im running 1500w with a 1400 and i dont see below 12.5v full tilt so you should be ok with 1 perfect with 2 x2 BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
Alex K Posted April 16, 2010 Author Report Posted April 16, 2010 Of course I would do the Big 3. I am going to order a Iraggi 180A alternator today too and get that installed asap. 180A alt, Big 3 in 0gauge, and a new battery and I should be good. I hope 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
