i need to know how to set my gains and bass boost on my, i got a new setup, 3 12's before was just 2, and it doesnt sound as loud or as powerful as with my two 12's
if you added woofers to the same amplifier, you changed the ohm load. which in turn can cause you to lose power if you wire it all fucked up, or even normally. dont touch bassboost (keep on 0/off) and follow that picture guide.
ok so how do i determine the watts by the amp or by the subwoofers in total. i have it wired at a 2.67ohm load to a 2 channel amp rated at 1080rms bridged, the subs are 800rms but overrated more like 600rms or 400rms.
Okay heres how this will go. Name the Kind of amp and Subs you are using State what Ohm they are such as Dual 2 ohm or dual 4 maybe Single 2 or single 4 then ill help from there,
you took the amp from wired at 1 ohm to 2.67 and spread out the power from the amp from 2 to 3 now, so thats why it got quieter.. you can invest in a bigger amp that does more at 2 ohms and prob have a better chance with getting louder with that
edit
i believe they are all D4s
Edited by Army_guy614
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
power acoustik silver edition sl-2400 at 1080rms, 3 power acoustik fubar 12 w 800rms dual 4 ohm
Change the amp to a hifonics 1610 and it will be a lot louder.(but still it would be better to just use 2 if they are louder.)
PA amps are overrated (by a lot), the hifonics will put up the wattage if it has enough voltage.
Edited by kirill007
edit
well my amp isnt a mono block its a 2channel, it was wire at 2ohm load.
listen to army guys hes been in longer then me but i know what hes sayin is right when you take 2 subs to three subs your spreading the power out so its not say 500 watts each its like 450 somthing like that
