i was thinking about buying a re hc 18 from a friend from work. but before i wanted to get it, i want to know the specs of the sub. i tried looking it up and i didnt have any luck on it. can someone help? and also is there a recone kit for this sub? thanks
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
edit
just looked it up, looks like a pretty nice sub to me
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
edit
i been trying to look it up, its a really old sub from re audio. i heard it, sshhiitttt, part of the store i work in was shaking. lol. but i just wanted to know the specs so i can make sure i wont end up over powering it.
Company: RE Audio (Resonant Engineering)
Model: HC18
Available = No
Last update: 10-Sep-2003
Type: Standard one-way driver
Shape: Round
Piston Type: Cone
Piston: Kraft pulp cone with carbon fiber matrix.
Suspension: Rubatek foam surround. Progressive spider.
Frame: Cast aluminum basket.
Voice Coil: 4-layer copper voice coil.
Terminals: Tork-Tite terminals.
Magnet: Triple stack magnet.
Fs = 27.3 Hz
Qms = 6.8
Vas = 7.631 cu.ft
Xmax = 0.827 in
Xmax (parallel) = 0.827 in
Xmax (series) = 0.827 in
Sd = 187.6 sq.in
Qes = 0.96
Qes (parallel) = 0.48
Qes (series) = 0.48
Re = 2.2 ohms
Re (parallel) = 1.1 ohms
Re (series) = 4.4 ohms
Z = 4 ohms
Z (parallel) = 2 ohms
Z (series) = 8 ohms
BL = 2.54 lb/A
BL (parallel) = 2.54 lb/A
BL (series) = 5.08 lb/A
Pe = 600 watts
Pe (parallel) = 1200 watts
Pe (series) = 1200 watts
Qts = 0.84
Qts (parallel) = 0.45
Qts (series) = 0.45
1-W SPL = 88.5 dB
1-W SPL (parallel) = 91.5
straight from bass box pro.
Model: HC18
Available = No
Shape: Round
Piston Type: Cone
Fs = 27.3 Hz
Qms = 6.8
Vas = 7.631 cu.ft
Xmax = 0.827 in
Sd = 187.6 sq.in
Qes = 0.96
Qes (series) = 0.48
Re = 2.2 ohms
Z = 4 ohms
Z (series) = 8 ohms
BL = 2.54 lb/A
Pe = 600 watts
Qts = 0.84
Qts (series) = 0.45
1-W SPL = 88.5 dB
nice, thanks. i guess its rated 600rms, single ohms or dual? i hardly understand half the specs there. kinda a car audio noob if you ask me, but im catching up to the game though. and also need to see if there is a recone kit for it.
its 600 per coil. so 1200rms. if you see 3 specs (such as Z which is ohm load, look at the parallel/series specs and not the lonesome Z specs)
so its a dual ohm. and im able to connect it to 1ohm right?
  • Who's Online   0 Members, 0 Anonymous, 1194 Guests (See full list)
