X1200M
chevytuck95
I've been told to get rid of it but its what i have for now so just a lil help please. Its a momo block and it has two out puts now i believe mono just is saying there the same no balance no fade. Its rated at 1200 at two ohms the sub to be hooked up is dual two cant i just run one voice coil to each side to try and get the most out of this amp till i replace it? thanks for any help
1995 Honda Accord Coupe
still building only thing done is big three and one run of stinger 0 gauge.
Feedback
YES.... hook up one coil per side. :good:
Does this smell funny to you? Its your sister :roflmao:
io tengo un amplificador JBL el cual nose qe pasa pero ultimamente se protege!!
nose si los subwoofer estan haciendo algun falso o qe peo estoi jodidoo jaja
nos vemos ayuda plis!
thank you sgtskip
Feedback
If you hook one coil up per speaker terminal then you're going to be running the amp at a one ohm load. Is it stable at one ohm? On my Sundown amp the speaker terminals are paralleled inside the amp. If you parallel a dual 2 ohm sub you'll get a one ohm load.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Come on dude, are you TRYING to make him blow his amp up or are you just stupid?
Monoblock means 1 channel. The 2 sets of outputs are attached together (internally paralleled if we're gonna get technical)
They just give you 2 sets to make it easier to wire up multiple subs.
If you wire the coils in parallel you'll get 1 ohm and probably some nice smoke coming from your amp. Or it'll sit there in protect like a metal turd.
Wire them in series and run it at 4 ohms.
10.x volts fo' life!
thank you thats what ive done now and it works as good as its gunna get. its only putting out about 650 rms which sucks ass but it still pushes that 18 famously
Feedback
  • Who's Online   1 Member, 0 Anonymous, 705 Guests (See full list)
