ChevyP Posted April 23, 2010 Report Posted April 23, 2010 I have a audiopipe 1800d powering two AP txx-c 15" wired at 1ohm when I turn the bass remote to half the amp goes into protect, I have about 2weeks wih this setup it just starded dong this yesterday. what could he the issue
k3n12ock Posted April 23, 2010 Report Posted April 23, 2010 Recheck all your wires and does it happen without the bassknob? 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
Pauliesnite93 Posted April 23, 2010 Report Posted April 23, 2010 is the amp on the box? if so you could have rattled the sound card iin the amp loose. i just did it to my power acostik 5500 bamf. and it was having the same problems the your having. all i did was push the sound card in and took it off the box. Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up
ChevyP Posted April 24, 2010 Author Report Posted April 24, 2010 found the problem,it was the fuse holder under the hood that was bad. thanks for the guys.
Guest Posted April 24, 2010 Report Posted April 24, 2010 found the problem,it was the fuse holder under the hood that was bad. thanks for the guys. we gave you guys?
Neo_frog Posted April 24, 2010 Report Posted April 24, 2010 we gave you guys? Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
EricR Posted April 24, 2010 Report Posted April 24, 2010 we gave you guys? Lulz i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
