Main thing was, 3 are more "burnt" looking than the other 3... In a V6 motor..
yeah, it happens. as long as she's running smoothly you have nothing to really worry about. just make sure you gapped your new ones (they come pre gapped but often get bumped around in shipping.)
With new ones gapped correctly I believe, ran shittier (misfiring idle) than when I had these Motorcraft plugs in. Plugs I put in were NGK V-Power's.
How would I clean these off to test and rule out my spark plugs causing my issue? Ran fine with Motorcraft plugs, lol.
take a nail file to the gap area then blow the sand/residue off after you've made it shine.
you did replace one at a time didn't you? trying to replace all at once is a good way to switch a wire around.
Cool, thanks.
Yes one at a time, checked the firing order a bajillion times to just to double check.
i use wd40 and a small wire brush. did u check the distributor cap and rotor cap?
I know a lil about everything so dont call me Mr. Know it All.
They should... I told the auto parts store what vehicle and motor everything...
  • Who's Online   0 Members, 0 Anonymous, 1696 Guests (See full list)
