you can also run 1 amp per coil. No strapping involved. It will work fine this way.
Some amps have a slave/master where gains will automatically be matched. If your amps do not, then you have to use a meter and set them as close as possible to eachother.
But, the easiest, cheapest, and most reliable thing to do is to get a single 2000-2500w @ 1ohm amp and a dual 2ohm coil woofer.
There you go thats what im saying
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
one amp per coil will work gain match them and presto u got.
I know a lil about everything so dont call me Mr. Know it All.
match the amp with a dmm and ur set
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Maxx-link is a gadget that links 2 un-linkable amps... I haven't used it yet but seen systems with maxx-link...
Haven't tried 1 amp, 1 coil setup but in case your up for it... You may want to check the Voltage each amp is putting out with a volt tester before running them.
1 amp per coil is what we had to do back in the day, just try to match it all up.
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
Since the amps are strappable... should i strap the amps and run sub at 2 ohms? Or should i just run 1 amp per coil at 1 ohm per coil?
What should give me better results?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
If you have the option to strap them I would do that. Then all your controls (gain, HPF/LPF, etc) come from one amp, and there's no need to worry about matching the gains perfectly.
But technically both ways will work just as well.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
I agree with this
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
So just to make sure im 100% positive that i understand this
If running the amps strapped...
I should buy a sub that is D1 and wire it in series?
Correct?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
Id buy the D4 and wire down...
HU...Pioneer 5900IB
Wireing...Stinger
Amps...(1) Modded Stetsom 2K6..
Batts...(1) Stinger 2150
SPL Subs...(2) DD 9515 Hybrids
Daily Subs..(1) Mmats P3.0 15
N.S.P.L.
2012 NC State Record Trunk 1801-3600
2012 World Record Trunk 1801-3600
2011 NC State Record No Wall 0-24"
2011 NC State Record No Wall 0-24" Hardcore
2011 World Record No Wall 0-24"
2011 World Record No Wall 0-24" Hardcore
2010 World Record No Wall 0-2500w
2010 NC State Record No Wall 0-2500w
2009 NC State Record No Wall 0-24"
2009 NC State Record No Wall Hardcore 0-24"
