Just a little something from before I redid the box completely. Updates tomorrow! It sounds a lot better and also I tweaked the settings on the amp and head unit so you will hear a big difference. Edited by BluX
BluX
2001 Ford Explorer Sport
  • Mach 5 MJ-18 (4 Ohm)
  • Alpine MRP-M1000
  • Alpine 9813
BluX
  • Alpine MRP-M1000
  • Alpine 9813
Okay... so last week, I built this box. I had went to Home Depot and had them cut my wood, which resulted in extremely f*cked up cuts, so I had to rush home before it got dark, after waiting 4 hours for them to cut my wood, I went over the cuts and tried to save a few pieces, had to buy a whole new sheet and make some cuts myself. Most of the cuts were either an inch too small or an inch too big. Luckily, I was able to borrow a table saw and I ended up being able to build a semi-decent box. I rushed home, assembled the box and quickly glued it together. The next day, I put the box in my Explorer and went to see how it sounded. First impressions... DAMN! It has been almost... 4 years maybe, since I've had a system. So, tonight, my goal is to re-glue all potential leaks and carpet the biatch. I was able to see light coming in from where the pieces of wood meet together, so I know there were leaks. This thing is not going back in my truck until I am completely sure that there are no leaks. I probably went overkill with the glue, but better safe than sorry, right? Other than the carpeting and sealing up leaks, I will be sanding the part by the port that sticks out about 1/8th of an inch too far.
Hopefully I will see a difference after all this work. More pics to come.
Edited by BluX
BluX
  • Alpine MRP-M1000
  • Alpine 9813
With carpet... install pics later.
BluX
  • Alpine MRP-M1000
  • Alpine 9813
Did you use any clamps/screws?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Who needs screws?
But I agree, should of at least used to clamps.
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
I had one C clamp lol... I did use screws, yes, but on the 1st baffle, most of the screws were used, then the 2nd baffle, only 4 were used and those screws were tightened into the braces. Shoulda used more clamps :(
BluX
  • Alpine MRP-M1000
  • Alpine 9813
more clamps or more screws = less gaps.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 1 Anonymous, 1998 Guests (See full list)
