JZeFF Posted May 3, 2010 Report Posted May 3, 2010 Do i only need to connect the RCA cables to the Master amp? Or do i need to split the Signal and run it to both amps? Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
hdorre Posted May 3, 2010 Report Posted May 3, 2010 Do i only need to connect the RCA cables to the Master amp? Or do i need to split the Signal and run it to both amps? You usually only need to run the RCAs from the headunit to the master amp. After that, youd run a wire from "Master out" to "Slave in." Check the manual on your certain amp. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
treossi Posted May 3, 2010 Report Posted May 3, 2010 yeah RTFM ftw, but on the sundowns you run rca's to master amp, BR out from master to BR in on slave.. connect negative wires between amps together.. and postitives from subs go to master amp.. negative from subs go to positive of slave amp which brand of amp are you running ? Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Sanitarium Posted May 3, 2010 Report Posted May 3, 2010 yeah RTFM ftw, but on the sundowns you run rca's to master amp, BR out from master to BR in on slave.. connect negative wires between amps together.. and postitives from subs go to master amp.. negative from subs go to positive of slave amp which brand of amp are you running ? This is the same setup for AQ amps too btw.
JZeFF Posted May 3, 2010 Author Report Posted May 3, 2010 Haha, i got my amp used, so no manual. I did just notice the amp has the single "signal out" port though... is it just a single RCA cable? DAT amps btw Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
Carnag3 Posted May 3, 2010 Report Posted May 3, 2010 Now after strapping two amps (mine being AQs) how would you wire up two dual 2ohms for .5 ohm? 2000 Blazer 4dr -24" Boss 330s -Lowered 2/3 -5000k Hids w Projector Retro -Candy tails -LED interior lighting -20% tint 35% windshield -Alpine 9886 HU -RF P1462 Dash -RF P1652 Front -RF P1652 Rear -Two 18" Fi BTLs -MB Quart Onyx 4.80 -Two Audioque AQ2200Ds -Xs Powerr D5100, 2 Powersafe G31s -Knukoncepts 1/0 wire -Mechman 270 Alt w Boost Module -10.4 Net @ 28hz 140sq.inch of port My Youtube Channel!!
aleroking Posted May 3, 2010 Report Posted May 3, 2010 Now after strapping two amps (mine being AQs) how would you wire up two dual 2ohms for .5 ohm? if its strapped and the pair is seeing .5, then each amp would be running at .25 which would probally be to low. 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
splzx3 Posted May 3, 2010 Report Posted May 3, 2010 wire down to a 2 ohm load and the amps will see it as a 1 ohm load ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Carnag3 Posted May 4, 2010 Report Posted May 4, 2010 wire down to a 2 ohm load and the amps will see it as a 1 ohm load Basically I want to run the subs at .5 instead of 1ohm to give me more amplifier output. Would keeping the subs wired for 1 ohm make the strapped amps see a .5? 2000 Blazer 4dr -24" Boss 330s -Lowered 2/3 -5000k Hids w Projector Retro -Candy tails -LED interior lighting -20% tint 35% windshield -Alpine 9886 HU -RF P1462 Dash -RF P1652 Front -RF P1652 Rear -Two 18" Fi BTLs -MB Quart Onyx 4.80 -Two Audioque AQ2200Ds -Xs Powerr D5100, 2 Powersafe G31s -Knukoncepts 1/0 wire -Mechman 270 Alt w Boost Module -10.4 Net @ 28hz 140sq.inch of port My Youtube Channel!!
