Best amp for 2 12 alpine type r's?
Need some help i have 2 12" alpine type r's. i want a good amp that wont over heat when i wanna pound and drive around for awhile. any suggestions?
JENSEN 7" FLIP OUT H/U
*2 5 1/4 PIONEER DOOR SPEAKERS
*4 PLANET AUDIO TWEETERS
*2 6X9 PIONEER SPEAKERS
*2 12 POWERBASS 3XL'S
3000 WATT POWERBASS AMP
Guest jbinn
before you make a decision the above user is right, you want to make sure your ohm loads are adequate... I'd suggest the MRP1000.1 for a 2OHM system.
Alpine m2000 or aq2200 depending on ohm load of subs, alpine for D2's and aq for D4's
alright thanks man im gonna check it out. so wat i can find. :drinks:
depends if your subs are dual 4 ohms or dual 2 ohms. if dual 4's i would get 2 mrp500's and wire the subs in parallel to get a 2 ohm load each. or if they the 2 ohm get a mrp1000. orrr what imma do is get a t1000.1bd that does 1639rms (birthsheet) at 1 ohm and wire down the 2 4 ohms down to 1 ohm :P gotta be very careful with my gain lmao
they are 4 ohm
where can i find the aq2200 amp at online?
Aq can be found only on audioque.com
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Dont think the type r's would like 1k+rms each. Referring mainly to the AQ.
X2 stick closer to the rms. I ran 2 type r's with a mrp-m850 to each with the gain turned down a bit and they would get stinky after a minute or so at full tilt
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
  • Who's Online   1 Member, 0 Anonymous, 1935 Guests (See full list)
