Have any of you all had this problem? When the car is off the radio works fine, but as soon as the car is running the radio will light up and all but no sound. Cut the car off and the sound returns.
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
what kind of radio do you have? check the wiring again. I know my little clarion likes to go dead about once every 2 weeks for no reason, we just take the power out wait 2 minutes and plug it back in and it works =\!!
15" re sx 4.1 cub at 33hz box by coolwazabi
its not mine. Its a friend of mines cd player. It works fine if the car's engine isnt running, as soon as the engine is running the sound cuts off. I believe it is a old JVC unit.
Edited by lovellsz
Sounds like something up with the ignition to me.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
probably accidentally hooked ground or ign to light dimmer... when car turns on its positive, when off its neg or vise versa... just use a volt meter and check that real fast, should be a easy fix
ok, thats what i was going to check, but i figured i would ask in case it was something else.
now how difficult is it to remove a radio out of a cavalier? Does the whole dash have to be taken out?
  • 14 years later...
2 minutes ago, Shaun davis said:
Figure out what it was .  I’m having the same problem .  Car amps and speaker work fine when car is just in the in position but as soon as I start it up sound goes crazy .  Basically shuts off
2-12 JL
jd 500/1
rf 400.4
jL 6.5 and 6x9  c2
You just resurrected a 14 year old thread, pretty awesome.
Is this a new issue or you are just finishing a new install?
