how overrated is the power acoustic bamf 5500
Flint_810
It has 200 amps of fusing
200 * 14 = 2800
75% efficiency (just a guess)
2800 * .75 = 2100
So IMO with a good electrical, that's what you could see. I haven't had first hand experience, though.
that would be if i have the gain turned up half way to see atlease 2000 watts
[color="#2E8B57"]size="4"]1998 buick century
stock elcetrical for now
pioneer 3100 avh dvd HU
(12)power acoustik tweeters
(1) PA BAMF 5500
(1) FI 15" BTL HEAVY SUB!!!
(1) kenwood 720 4cahnnel amp on da way
(1) 20ft run of rockford fosgate 1/0awg
(2) 1/0awg to 4awg reducers
(2) memphis front speakers
(2) kenwwods 69ie 6x9's
(1) deep cycle batt on the way
(1) 5cft box tuned to 32hz after displacments
ALOT MORE UPGRADES TO COME!!!!![/size][/color]
Dont trim it down just get yourself some 0 to 4 ga reducers and it will fit fine......I had 4 of these amps and would guesstimate that they put out about 2k but possible up to 2500 with good electrical......not a terrible amp for the price.
thanks man i'd appreciate the info. where can i find o to 4 awg reducers at? and where you do reccommend setting the gain at if im running 1 fi btl 15"
(1) PA BAMF 5500
yu did say minimal 4 ga or did yu mean maximum??
im looking at the pa amp now and on the power inputs it says requires minium true 4awg to operate
(1) PA BAMF 5500
are you planning on running the amp at 1 or 2 ohms.....the output at 1 ohm is rated at 3200w and 2500 at 2 ohm?
oh yea 1ohm but i know its not gonna put out 3200x1 i wish it wold then io wouldnt have to touch my gain setting lol
(1) PA BAMF 5500
Using the reducers wont hurt anything.....if anything it will be alot easier and cleaner then cutting away wire and trying to jam 0ga into a 4 ga hole
lol your right about that, thats makes good sense
(1) PA BAMF 5500
I HAVE A GUY RUNNING TWO OF THESE ONE PER DD 3512. HIS VOLTAGE FLOATS AROUND 14.3 AND @ FULL TILT IT DROPS IN THE 13.6 TO 13.8 AREA. THESE WILL DO NO WHERE NEAR THE 3200RMS @ 1. HOWEVER, IF YOU DO THE NECESSARY ELECTRICAL UPGRADES; HO ALT AND SECONDARY BATT TO GET YOUR VOLTAGE IN THE 14+ AREA YOU SHOULD SEE 2200 TO 2500 OUT OF THESE. RUN 4 GUAGE TO BOTH OF THE POWER AND GROUND INPUTS. THEY ARE ANGLED SO IT WOULD BE HARD TO FIT 0AWG. IF YOU ARE RUNNING MULTIPLE BATTS THEN RUN 0AWG TO 4 GUAGE AT A 1 IN 2 OUT FUSE DIST. BLOCK.
  • Who's Online   0 Members, 0 Anonymous, 1163 Guests (See full list)
