RE Audio 8inch REX Series
NYC54
http://cgi.ebay.com/..._fvi%3D1&_rdc=1
hear are the specs the 10" and the 8" are the same
8" are $140 a pair plus you get $20 off as a smd member so $120 a pair + shipping
Why are you on here spamming? You are trying to sell your product in an unapproved area and you are a really new member. I am thinking this is not appropriate.
Mid bass is usually the idea of running about 80/100hz - 350/380 hz bandpass filter on them
At these frequencies are the weak point the subs do not make, and the mids never could make
This is why a pro audio bass driver will work best, a Fs of about 80 - 100hz even up to about 120hz. Woofers with those specs, and usually a higher Qts, towards the 0.6 - 0.8 would be best in this range
I personally just made my own mid bass, I have installed on one side, and the bass range I'am making, I never heard in my truck before, the same bass notes as going to a club, or concert, not really low, just pounding, and really fills in the low vocals
This is usually where a mid bass speaker is meant to be played
Throw a 8" sub in the door, and your just getting free air sub bass, probably centered in the 60 - 80hz range
No need to yell. :P(pls don't use caps. :P)
The best would be a 8 inch that can play range of around 8O-400 hertz without problems.
Just search a midbass there are quite a lot out there.
Then look at the freqeuncy response.
EDIT: Oh, and by the way, a full range speaker is a speaker that plays the whole range of sound.
Not one PA speaker uses full range drivers because most of the time they have a low power handling.
A full range speaker will give some midbass, but not more then a dedicated 6.5 inch midbass.
oh ok i see finally im starting to understand lol thank you for the info , when you say pro audio you mean most of the stuff parts express sells like b&c , tang bang , morel etc. ?
Thank alot for the explanation :good:
i cant really find 8 inch 4 ohm mids though the only ones that ive seen is the arockford fosgate that meade uses , i have a question about freqeuncy response , do the speaker can say anything past 400 hertz ?
  • Who's Online   1 Member, 0 Anonymous, 1022 Guests (See full list)
