P4killer_ Posted May 13, 2010 Report Posted May 13, 2010 Stinger SVMR Voltage Meter Posi- Posi on amp/ voltage to be metered Neg- Ground Acc- Remote HU Lead Question here is can I run the ground to the ground on the amp, because I dont feel like buying a pack of lil o-rings to mount it to my back bat ground nor do I feel like taking out my HU and desoldering that ground to add in the meter. Also I have a spool of 18 awg sitting around, this should be ok for running the connections right? Just a quick question while Im waiting for an hour between classes thanks. P4Killer Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
jmitch Posted May 13, 2010 Report Posted May 13, 2010 yes u can hook everything to the amp. that way u can read what the amp is actually seeing. I know a lil about everything so dont call me Mr. Know it All.
skittlesRgood Posted May 13, 2010 Report Posted May 13, 2010 ^yep If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Neo_frog Posted May 13, 2010 Report Posted May 13, 2010 There's an insignificant amount of current going through a voltmeter so you'll be fine with almost any size wire. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
