hamel52 Posted May 17, 2010 Report Posted May 17, 2010 should the remote wire going to your amp read a different voltage than your power? i tested with a dmm and the power was at 14.2 and the remote was only at 13. does that mean anything... oh by the way i cant get my amp to work it worked for about 5 min then shut off and hasn't worked again.
hdorre Posted May 17, 2010 Report Posted May 17, 2010 The remote wire is about 18 gauge so it carries less current. That says something... On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
hamel52 Posted May 17, 2010 Author Report Posted May 17, 2010 yeah thats what i figured just cant figure out why this amp doesn't work.
audiofanaticz Posted May 17, 2010 Report Posted May 17, 2010 A headunit remote wire almost always will read lesser on voltage since the headunit is wired thru the cars factory electrical system and has lots of resistance and the power wire for your amp is a way thicker gauged wire that will have way less resistance because it does not fish thru the entire electical system and fuse panels powering every electric component in your vehicle. If you think your remote wire is the problem, try jumping straight 12 volts from your amps power wire to the remote terminal. If it dont turn on your amp is probably bad, or you have a bad connection on your power wire, or ground.
hamel52 Posted May 17, 2010 Author Report Posted May 17, 2010 thank you man i just did that and everything works perfect with the remote jump so i know its a bad remote... your a savior i thought i was going to have to send another amp back to sonic
