T-Line vs Slot
im just wondering what the advantages of have a t-line instead of a slot port are, or vise versa
well obviously a t-line the port is longer
thanks!
thanks!
From what i understand, T-Lines are da shiz (technical terms). If you can, do a T-Line. They hit lows like crazy. Only problem (correct me if i am wrong) that i know of is that they have to be HUGE. Slot ports are easy to make, easy to calculate, and generally smaller than T-Lines.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
t-lines are actually easier to calculate than a slot port (as it doesnt require a pre-made calc)
t-lines are in essence the perfect box for your woofer. each box is designed to the woofers specs. they play music really well and bring out the best in most any woofer.
it is true that a traditional bass reflex design can be louder than a t-line, (with the right woofer) that t-line will sound better and play more flat.
t-lines are generically quite large and very hard to design however.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
With a slot, you specify around what hz frequency you want your sub to peak at, where as t-lines are more flat with response. I haven't had a t-line tho so I can't say which one is louder
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
that seems like an oxy moron
there easier to calculate but harder to design?
so are t-lines or slots going to give me more dbs
not an oxy-moron by any means
i can calculate required dimensions in a matter of minutes but drawing it up to fit in a vehicle with minimal turns proves to be difficult
t-lines are not used for db's
mainly because a general rule of thumb it to use half rms power so you do not blow your woofer. there is no back pressure
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
so t-lines are more for SQ
kinda
their main purpose is efficiency
but they do sound really good
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1784 Guests (See full list)
