Pioneer DEH-780mp not powering door speakers?
Well, hooked up a Pioneer DEH-780mp into my buddy's 1998 Chevy S10. Worked great for a bit, then he went to turn the passenger airbag off, and the head unit no longer powers the door speakers. The sub is working fine... it's just like a muffled sound. Basically just bass that we're getting from the head unit. Any suggestions? It worked fine and dandy until he turned the passenger airbag off, then it just quit working. We've tried settings on the head unit, no avail. Although i didn't have the manual for it... so i'm not exactly if there are more settings deeper into the HU's controls. The HU Illuminates and produces bass. that's about it.Any help or advice, or linking in the correct direction would be greatly appreciated, trying to get this taken care of ASAP.
Thanks!
-Brandon
-10" Alpine type r
-Kenwood 8104d
-Kun 4 gauge
~Not bad for the price
try turning it back on,if it goes back to right its the switch if not.... well. i wouldnt know why the air bag switch would affect any thing but the air bag
2003 CHEVY SILVERADO REG CAB
H/U SONY W/ IPOD TOUCH
new build
2 dc audio lvl4 xl's
rd audio 3250
box is behind the seats
below the window
3.44 after tuned@34 htz
147.3@44 htz & getting louder
^This
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
Seems weird that that happened after he switched the airbag off....
I had that happen in a truck I did an install in and the problem turned out to be a wire that came off one of the door speakers and was making contact with bare metal on the inside of the door, so i suggest you make sure EVERY wire is in it's place...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Hmm. Well, he was playing with the airbag switch, didnt make a difference. I'll mess with it some more. Also, to AudioAddict, One loose/bare wire touching metal can short the entire deck out, or put it into "protection" mode, like a faulty ground may cause an amplifier? Is this confirmed? I see the plausibility, just have never experienced that type of problem. I'll have to look into every speaker. Thanks for the help guys, any more information/tips? I thought it could be the fuse or the wiring harness, but i just dont see how that could be the problem with my situation and how it went down.
Thanks again!
-Brandon
-10" Alpine type r
-Kenwood 8104d
-Kun 4 gauge
Thanks again!
-Brandon
That's true, but in my case I didnt think that was the problem at first because the hu didn't go into protect mode or blow any fuses and the subs kept playing, when I took the door speaker out I took the wire off the bare metal and all the speakers started playing again.....It's worth a shot, just trying to help...!:)
  • Who's Online   0 Members, 0 Anonymous, 932 Guests (See full list)
