zayres29 Posted May 21, 2010 Report Posted May 21, 2010 i have 2 AQ hdc3 18s my box is around 13 cubes tuned around 37hz and im having trouble keeping my screws in does anyone else have this problem did i do something wrong tomorrow i plan on putting some liquid nails on them but i was just wondering if i did something wrong for them to be doing that thanks Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
NcHalfrican Posted May 21, 2010 Report Posted May 21, 2010 screws have no use after the wood glue has set...could always fill in holes with glue and mdf dust
teamace24 Posted May 21, 2010 Report Posted May 21, 2010 So your screws come loose after a lot of pounding, or when you tighten them do they not stay tight? If its the second one then you are not hitting the wood right splitting, but if its the first then yes just cover the holes from the nails with luiquid nails or silicone. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
zayres29 Posted May 22, 2010 Author Report Posted May 22, 2010 yeah its the first one when i pound it they come out i pre drilled every screw so there is no splitting Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
corona_jeff Posted May 22, 2010 Report Posted May 22, 2010 the screws holding the subs came out or the ones holding the box together did? Dustin had that problem with his woofers ... had to get screws with bigger heads. EDIT: you can still split the wood even if you pre=drill
zayres29 Posted May 22, 2010 Author Report Posted May 22, 2010 the screws holding the box together i havent checked any od the screws holding the subs in yet im 99.999999% i didnt split an wood Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Steph3n1 Posted May 22, 2010 Report Posted May 22, 2010 the screws holding the box together i havent checked any od the screws holding the subs in yet im 99.999999% i didnt split an wood theres 2 things you can do drill out a little bigger hole on the mounting plate in the sub and put a much larger screw in. or if you can get to the bottom to the subs from the port then bolt them down to there fastened on both sides almost 100% garuntee they wont come out then 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound)
zayres29 Posted May 22, 2010 Author Report Posted May 22, 2010 theres 2 things you can do drill out a little bigger hole on the mounting plate in the sub and put a much larger screw in. or if you can get to the bottom to the subs from the port then bolt them down to there fastened on both sides almost 100% garuntee they wont come out then the sub isnt the problem its the screws holding the port in Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
