i got a wiring speakers to amp question for future reference ok so lets say i get my door panels fiber glassed and all those goodies and i get 3 sets of components per door and i got 4 channel if i wire 3 sets to each channel that would give a 1.3 ohm load to each channel now theres not many 4 channel amps out there that are stable at 1 ohm per channel .. would you just use seperate amps for like each pair or wiring them 1.3 on 2ohm stable 4chan amp be fine ?? any one done this before
so you only plan on using 2 channels of the 4 channel amp?
you could run 2 of the channels at 2 ohms each and 2 channels at 4 ohms. (2 sets and 1 set)
Wait, so you want 6 speakers and 6 tweeters per door? You better have some retarded bass to need that.........
And to answer you question, there is no 4 channel that is 1ohm stable ~To my knowledge~.
Only thing that might work is the old Sony Mobile ES amp. It's HUGE and RED. The last two channels are .5ohm stable, I will go look at model number when it day light.
Rockford not 1-ohm stable stereo?
Maybe not, idk, they have powercube measurements @ 1-ohm
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
Not for any of their 4-channels..... all I see is down to 2ohm.
idk i just saw cube measurements to 1 ohm and
100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
which would make me think it would be straight @ 1-ohm stereo
this is from a 600-4
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 1332 Guests (See full list)
