someone correct me if im wrong. cant he do series/parallel and get 1 ohm?
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
no? so there is not amp compatable .25 ohm
no. most people on this forum have no concept of this idea
the amount of amperage required to feed an amp at that ohm load would be massive and require many large batteries for capacity. then on top of that you would need alts that could charge fast enough to keep up with the draw.
if your voltage so much as thinks about dropping the whole thing is fucked.
stick to one ohm
and i suggest you learn what series/parallel wiring is
like he said^
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i have them run parallel now on audiobhan1200dmono ugraded to 2200 and it does fine and dont run hot not even warm should i keep it hooked up or what? i dont want to burn up the amp
stick to one ohm
like he said^
well thats what i am asking you guys if thats ok
-wire the individual coils of one sub in series
-do this for all 8 subs
-now connect all subs in parallel
gives you a one ohm load
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
thanks for the info
what subs are these, the Hifonics Hifi 12" D4 right? 300 rms a piece and there's 8, so 2400 rms. maybe one of those rf 2500 will do or Hifonics HFi2500D
X2 on the t2500 but wouldn't you get significant impedence rise? I know it varies per frequency, but still
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
impedance rise does not factor into a daily driver enough to worry about it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
stick to one ohm
like he said^
not that I agree with running at such a low ohm load, but how much current is required at the input of the amp is based on efficiency and output, not
what ohm load it is driving.
True, most amps are not as efficient as the load drops, but it is not enough difference to require another bank of batteries or additional alt. If it is, that would be an amp to stay away from.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 1758 Guests (See full list)
