Fi Car Audio
kenwood kac-9104d and fi ssd 18
Mr. Yuk
hey guys this is my first post here and was just wondering what you think about this setup. I have an 01 yukon and this is going to be my first big system i have had a couple jl 12s and a kicker l5 12 in my old civic hatchback. I have the kenwood amp already which says it does 900rms at 2 ohms and is 1 ohm stable although id like to just run it at 2 ohms for heat reasons. just wondering if you think it would be enough for the fi ssd probably gonna run around 8 cubes @32-33hz sub up port back since it seems to produce the best output in my vehicle. specs on the sub seem to be fairly similar to the output of the amp so i think ill be ok but if not maybe some suggestions?
I'd get a better amp
ya a lot of people say that but never give a reason why? to me it seems like everything would work fairly well. But im kinda new to the not so mainstream stuff since thats all i can get my hands on easily where i live.
ya i think you have the newer version of my amp it looks identical just a diff model number it would most likely be a temporary amp just to get me by until i got something a little better. just wanted to try this out for a budget build first. i figure with all the room i have the 18 would be a good fun way to start using it.
I think the amp will do pretty good on it, plus your planning on building the box to the larger side of specs, which will definitely help with performance for the power you have, you dont have to throw 3xRms at a sub for it to sound and perform good.
¿ǝɯɐƃ ǝɥʇ
It doesn't have an adjustable subsonic filter. Keep that in mind..you cannot tune that enclosure any higher then 28Hz for it to be effective.
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
I was down at my local shop the other day and we were looking at the guts of one of my Powerbass amps, We pulled the backs off of a kenwood kac, Powerbass 1k and a Powerbass 5k and put them side by side. The kenwood amp was empty. it had almost no guts and what it did have was thin and chincy. It looked like a desert. On the powerbass's there wasn't an empty spot anywhere.
That being said my first amp was a kenwood. It did well for me considering. But for 20 bucks more why not get something substantial.
If you compare the original iPhone to a 3GS the 3gs has smaller components but it still works better (faster, 3g, more memory)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
