Tebo Posted June 2, 2010 Report Posted June 2, 2010 i just wanted to double check on this one. if i do 2 runs of 1/0 one pos one neg to the rear batt would i be okay grounding my amps the rear battery? 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
J00bles Posted June 2, 2010 Report Posted June 2, 2010 yes. thats a great way to do it. you can also ground your rear batt(s) to the frame, instead of running a 1/0 negative wire from front to rear. make sure you have all of your major grounds done in 1/0 though. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
Tebo Posted June 3, 2010 Author Report Posted June 3, 2010 i have my optima grounded to the chassive in my other car i would rather do the full run to eliminate any possible ground loops 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Hotdog Posted June 3, 2010 Report Posted June 3, 2010 i have my optima grounded to the chassive in my other car i would rather do the full run to eliminate any possible ground loops your not going to eliminate ground loops from running 1/0 neg from front battery to rear battery.. you eliminate ground loops by grounding all of your stereo ground's to a common location. Radio,Rca, Amp's , Crossovers, etc..etc.. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
PUNKYOU007 Posted June 3, 2010 Report Posted June 3, 2010 I wouldn't waste the wire running a ground from the front. You could actually take that amount of wire and do a couple runs to the frame if you felt it necessary. I grounded all my rear batts to the frame and all three of my amps are grounded to my batteries. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
