Amp shutting down at high volume
bmwsittinon19s
Has anyone heird of a amp shutting down because of a ground being to small ? have a eclipse 34230 hooked up running at 4 ohms to my highs i have 4 gauge power n a 8 gauge ground it cuts out n turns off at high volume... any input ??
ya man its the small ground. u need to have the same wire gauge on both power and ground. my old amp used to do that cuz the ground got loose. so it blew lol
Yes, the ground is as critical as the positive wire.
Maybe you are clipping hard, how did u set the gains?
And how did u ground the amp?
amps grounded to battery and then has ground off battery about 7 inchs long to frame of car... gunna go change the amp to the frame with a 4 gauge...
its running 4 emeince 8s and 2 comprestion drivers and its rain in parrlell at the amp is 4 ohms and gains about 3/4's up
Why is it that everyone thinks that power comes from the pos terminal?
I know for a fact in a regular battery (AA AAA D C) electrons store at the negative terminal and when a full circuit is made they go from the neg to the pos terminal.
Is this not true for automotive batteries?
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
tercel chris if u got neg comments why dont u keep them to yourself.. no one asked u anything about that reason for doing it because it has a ground 7 inchs away str8 to the frame which is already done from factory i made a mistake is that ok with u ?? go drive your tercel around buddy n think your cool!
Dude im sorry if that came off as an attack that wasn't my point. I never made an attack towards you or your intelligence or anything sorry if you think that. Everyone makes mistakes there is nothing wrong with that.
Tercel build R.I.P.
V-Dub
My feedback.
3/4 gain is quite high, but it depends on the HU, and if u don't hear any distortion it shouldn't be a problem.
Have you sanded the grounding spot down to bare metal?(sometimes people forget it :P)
  • Who's Online   0 Members, 0 Anonymous, 420 Guests (See full list)
