ok idk what the problem is but i had problems where they all wont play at all and now only 2 play and they sounds just like they should and the other 2 wont play at all ( they are all in chambers) i was just wondering what could be the problem
you think it could be the ground? or what
i dont think they are blown but idk someone told me i could tell if they were blown by pushing on them but idk what they will feel like if they are blown or not
Edited by zachfowler222
I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
r the lights on ur amp on ? r they hooked up to more then one amp ?
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
Okay so how many sub? what amp? how much power was each sub seeing. I need some more info. Also I live in the area you live in too man. Nothin else you could bring it over and i could give it a look over?
if you push down and hear like a scraping/scratching sound then they are blown.
ok i have 4 kicker cvrs 12s and its on a powerbass 3000 amp idk the actual rms on it and idk how much is going to each sub.
(sorry i dont have alot of info)
ok so i take it its not blown because i can push down on it and they all feel the same and there is no nosies or anything also i took them all out and the coils and everything are still intact
probably blown who knows. if you have a digital multi meter (aka DMM, you absolutely should have one) and set it to ohms and put it to each set of terminals on each woofer. if ANYTHING reads like some crazy ohm load like 40 ohms or something, or doesnt read at all, then that woofer/coil is blown.
given what little info is supplied its hard to diagnose. but maybe its how they are wired inside and one of the wires came apart from the 2 subs
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
do you know where i could pick one off these up at
