77-AUDIO Posted June 7, 2010 Report Posted June 7, 2010 (edited) The box is 36" wide by 17" tall and the depth is up to 30". Need help with the port length. I can do 2 - 6" ports or 4 - 4" ports 2 - 6" ports = 56.5486" of Port 4 - 4" ports = 50.2656" of Port I have up to 8 cubes of internal airspace before all ports bracing and subs. 3 - 10" Subs are DC Sound Lab Level 3 dual 1 ohms. Amp is a SAZ-1500D I need help on factoring the port length. Edited June 11, 2010 by Twiztid Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
OrionStang Posted June 7, 2010 Report Posted June 7, 2010 (edited) 2 6" ports at 12 inches would put you ~33.5 hz and net volume of 7.45 (Used .5 sub disp. and .5 bracing) Edited June 7, 2010 by OrionStang Quote SMD Super Seller My Feedback Thread
77-AUDIO Posted June 7, 2010 Author Report Posted June 7, 2010 2 6" ports at 12 inches would put you ~33.5 hz and net volume of 7.45 (Used .5 sub disp. and .5 bracing) I really don't want my box at 8 cubes it was just the max I can go! I would like a net volume of 4.75. I need a depth for the box and port length. thanks D Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
cthedinger Posted June 7, 2010 Report Posted June 7, 2010 Why are you using areo ports darryl? Quote If you have any questions PM me or Add me on Facebook CLICK ME! Shop at ct-sounds.com Subscribe to us on YouTube
jmitch Posted June 7, 2010 Report Posted June 7, 2010 what freq u tryin to get? Quote I know a lil about everything so dont call me Mr. Know it All.
77-AUDIO Posted June 7, 2010 Author Report Posted June 7, 2010 Why are you using areo ports darryl? I am not using aero ports what freq u tryin to get? 33 to 35 Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
77-AUDIO Posted June 8, 2010 Author Report Posted June 8, 2010 Daily bump looking to start on it this week. Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
bkolfo4 Posted June 8, 2010 Report Posted June 8, 2010 Assuming 4.75 ft net: (4) 4": 23.26" long for 33 hz, 20.35" for 35 hz (2) 6": 25.7" for 33 Hz, 21.8" for 35 hz Brian Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
77-AUDIO Posted June 10, 2010 Author Report Posted June 10, 2010 Assuming 4.75 ft net: (4) 4": 23.26" long for 33 hz, 20.35" for 35 hz (2) 6": 25.7" for 33 Hz, 21.8" for 35 hz Brian I am making my box 3.5 net so what length should I make my ports. I am going with 2 - 6" ports and they can stick out of the box no more than 4" Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
77-AUDIO Posted June 11, 2010 Author Report Posted June 11, 2010 i need a box design for 3 dc level 3 10" that has a net volume of 3.5^3 max outer dimensions are 37"Wide x 17"Tall x 20" Deep I need 50sq in of port tuned to 33htz. Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
