Almost every time i downshift from 4th or 3rd down to 2nd my amps cut out for long enough for me to notice, but not long enough to reset the amps.
Its just a short cutout of music and its not every single time, but its getting more frequent.
Any ideas?
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
honestly sound like a ground issue, when the load is greater on the engine the alt surges. might be causing this? I used to have some radio wine, only when i let off the gas or down shifted. Added some grounds...problem solved. just an idea :good:
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
I grounded my car best i can, soldered terminals and sanded down points. My amps are grounded to my rear shock mounts and my bug 3 was upgraded as well. I feel like if there is a problem with my grounds, then i shouldn't ever do car audio again because i can't do them any better.
Tercel build R.I.P.
V-Dub
My feedback.
I don't know if a ground is your problem, But I had bad ground noise even after sanding paint off and I tried a few different locations. I finally said F it and ran ground from the front battery to the back back battery,I haven't had a ground issue since.
Thats a great idea, but if i had the money for that, i would have done it a long time ago, i would try that for sure but i just don't have money for that.
Tercel build R.I.P.
V-Dub
My feedback.
I have done engine to battery, have not done engine to body (unibody) because the bolts WILL break if i pull them.
I'd suggest doing it, I managed to, I just found the factory grounding point, and replaced the thin as 12awg with 2 250 to 300 amp straps, it works fine.
It's a manual eh? I think I can remember from the vids.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
