Ok We just hooked everything up and the amp will power on but the sub arnt hittin any suggestion on what to check?
Trent
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
if its your first, you might have plugged it into the antenna signal wire instead of the 12v.
i did that on my first install (lol)
my first amp didnt have a turn on light or anything >.> it was like schoshe or some shit like that. but if its powering on then yea crank that gain!
Edited by lantusx
No I bought all the stuff from a friend he had it all installed in his truck when he pulled into my drive way to sell it to me then he took it out
~REFS~
make sure ur stuffs connected to the back of the head unit (RCA's)
if ur head units got a sub output, make sure its switched to on in the settings ;)
Edited by Quin
one of them said it could be the remote wire or the wiring of the radio and said I might need to go buy a harness since I just spliced the wires when I hooked it up
~REFS~
Make sure your main power fuse insn't blown also. Amps will still light up as long as they have a ground & REM lead going into them even if the fuse up front is shot.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Fianlly fixed it the guy who had hooked it up hooked the amp to the wrong side of the battery and the subs in the wrong place on the amp
~REFS~
man he needs his ass whipped, how did he do that?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
